Thread: Misc Oil Info
Created on: 04/25/10 08:46 PM
JESSE1212
JESSE1212's Gravatar
Misc Oil Info
04/25/10 8:46 PM
An informational site on oil:
http://www.nordicgroup.us/oil.htm#How%20Sludge%20is%20Prevented
And a list I found on another site for ZX14 oil filters:
Hi-Flo Filtro HF 303
Mobil 1 M1-108 and M1-110
K&N KN 303
K&N (automotive) is a hp -1008
Fram Ph6017A
Purolator L14612, is shorter than PL14610
Purolator PL14610, extended length, flows 7-9/9-11 gpm - conflicting info on flo in the posts
Ac Delco PF1237
WIX 51365
Hastings LF-113 short and LF- 240f is the longer version
Amsoil EAO 103
Napa Gold 1358
NAPA 1356, flows 9-11 gpm, which is the equivalant to the Purolator PL14610 flows 7-9 gpm (but if you type in "PS" before any of the NAPA numbers, you come up with the powersports series which in the case of the:
Purolator L14612
NAPA 1365/PS1365, same as the PL14610 except about .825" shorter
Fram 303
RE: Misc Oil Info
04/25/10 10:11 PM
"The 3000 Mile Myth
The 3000 mile oil change interval has been pounded into people's heads for decades. It had a scientific basis when engines used non-multi-weight, non-detergent oil. It no longer has any scientific basis, but it is still being promoted by certain entities, most notably the oil change industry in the United States. This myth is also sometimes known as the "Cheap Insurance Myth."
The 3000 Mile Fact
There are still vehicles that need 3K oil changes, but it's not because the oil goes bad after 3K miles. One example is the Saturn S series. These vehicles have a timing chain system that is very sensitive to clean oil because oil pressure is used as hydraulic fluid to ratchet up the timing chain tensioner. If varnish forms in the timing chain tensioner bore then this system can fail and the chain will become loose and eventually break. Dealers have gone as far as tearing out the normal service schedule (6000 miles) and leaving only the severe service schedule. If your engine is destroyed (under warranty) by a failed timing chain then the dealer will legitimately request evidence of oil changes. Unfortunately this problem usually won't manifest itself during the warranty period."
_________________________________________________________________
Kind of contradicts himself. I want my crank bearings NOT to act as a soft bed so big chucks can embed into the bearing insert and now add carbon knocked off the chamber. Isn't that a form of a hard diamond that can cut glass an shit? Cut bearing material for miles on end? Go right ahead. "Ain't My Bike!"
JESSE1212
RE: Misc Oil Info
04/25/10 10:29 PM
haha yeah not too sure about the 3000 mile comment but the rest seems unbiased
